1 - 5 of 5 Posts
Should I put a lining on my ported box? I read it decreases upper end sensitivity. Anybody have any opinions or experiences with and without lining?. Thanks
im not sure but maybe if you can try out both options. stuff it and measure and then remove it and measure.
you make like the result one way better.
Hi, I used spongy type filter foam I had lying around. It is about an inch thick. I stapled it in. What I did notice was that it dropped the tuning of the ports down slightly. I have yet to even measure it's response. It is a beast though. Very happy with it.
If I had some acoustic foam I would try it.
1 - 5 of 5 Posts
