Yes it's possible to run REW through Media Center to test the efficacy of your filters ( using your Accourate generated filters to convolve the REW test signal ) .
How to do this is best asked at their forum .
:sn:
Yes it's possible to run REW through Media Center to test the efficacy of your filters ( using your Accourate generated filters to convolve the REW test signal ) .Hello,
I am using REW v5.01 Beta 20 in windows 8.1. I use Acourate to generate FIR filters that are then used in the JRiver convolver.
Is it possible to measure the room response already corrected by the Acourate filter? I would like to measure it (keeping mic, etc, fixed) so I can compare the measurements without and with filter.
Thanks!
This post - http://yabb.jriver.com/interact/index.php?topic=86792.msg594719#msg594719 - has my setup for routing rew output through JRiver. You need to post your setup to get a specific recommendation on how to do it.I received an email from Acourate yesterday mentioning that I could just put the filter in the Acourate logsweep recorder, like you said.
However, I would prefer to measure the sound already affected by the filter, running Jriver, using another software like REW, to take Acourate out of the loop (except for the filter).
I suppose in order to check just the frequency response I could play a pink noise file at JRiver with the filter in the convolver and use the RTA function of REW, but I wanted to find out a method to perform the regular REW measurement to see the impulse response, waterfall, etc.
is it right that your measurement setup is completely separate to your playback chain? I don't understand how you're intending to get REW to playback through jriver in this case as REW doesn't have any external signal generator AIUI. To do this, you need REW to be able to route a signal through jriver. I'm not sure what "line out to preamp" refers to exactly but, if you don't have REW on the CAPS box, then you would need that line out to go to a line in on the CAPS and then route that into jriver.My setup:
CAPS Zuma (windows 2012, JRiver using Acourate filter in the convolver, ASIO) -> Playback designs MPS-5 -> pair of Krell 750mcx -> speakers
Measurement equipment:
Macmini (with windows 8.1 and REW 5.01 beta20) <-> Roland quad-capture (with loopback in second channel for timing) -> line out to preamp
<- Earthworks M30
Anything else you need to know?
no problem. I think a timing reference is hard with convolution in play, I think you need to find a way to route that signal through the same convolution filter. I thought it weeks be possible to open 2 channels of asio line in, use the 2nd one for the timing reference and then route the output of that channel back into rew using my mixer app. It didn't seem to work though. Hence it's easier just to use holmimpulse for this tbh (which works well enough).Matt,
Thank you. You are clearly an expert.
I am using a separate system for measurement because I try to keep the Zuma for playback purposes only, using Windows Server 2012 with audiophile optimizer.
Based on what you said it seems I should install REW in the Caps Zuma so it would be easier to run the REW output through Jriver.
I didn't quite understand how can I have a timing reference, but I will try at Interact.
Thanks
