1 - 4 of 4 Posts
Have you considered using 1 or 2 TC Passive Radiators in your design...some of the reviews of PR's are very promising... I will be building my new TC sub with this combo and will probably use the Crown XTi 4002 XTi 2 Series Power Amplifier as it has the power range I want and the sub harmonic synth....
I am confused. Is this a quote or are you asking about PR's?
It depends on the enclosure design, tuning, and power level whether or not you need 1 vs. 2 PRs. Generally you need two for a high powered sub when the PRs are of the same size...
1 - 4 of 4 Posts
