1 - 4 of 4 Posts
Hi i have a turntable harmony usb-1.
I have two choices to plug in my receiver ( pioneer vsx60) :
1) Use my pre-amp nad pp2i (turntable set on phono)
2) Use the pre-amp on the turntable directly ...
What will be the better choice ?
Ok thanks for the response, but i already have the nad pp2i so this is not for the price ...
Understood. I was using that as a gauge of relative circuit quality. I am guessing the quality of the preamp in the turntable is the higher of the two, would use it. Plus that way the interconnect is a line level signal, a minor plus, so the high impedance cartridge signal has a shorter path before getting buffered and amplified.
1 - 4 of 4 Posts
