1 - 3 of 3 Posts
Does anyone know the cutout diameter of the 4" Precision Ports. I have some on order and I'm trying to get ahead in the build. Also what is the OD of the tube? THanks so much. Sorry for the dumb question.
I don't, but are these from Parts Express? If so, their tech support guys are fantastic and I'm sure they'd have that info handy. Worth a call anyways.
The Precision Ports are designed to use the inside flare as a template, it is approximately 6.25" diameter.
But as Steve from Precision Sound Products recommends:
"If you do not have it yet, we always suggest that you have the Precision Port in hand before making any cuts on your enclosure."
OD of the tube that I have is 4 and 3/16ths.
1 - 3 of 3 Posts
