A friend and I are building a new set of speakers from scratch. It's a ported MTM design. To maximize the performance we decided to go with the flared Precision Ports.
Here's where the quandry pops up -- when I calculated the port length, it came up with 4.45".
The instructions for the port say
Well, the problem is that 4.45-5 = -0.55. Unless we're getting into some metaphyscial discussions, we've got a problem.. what can we do? Just use regular 3" PVC pipe instead of the flared ports already purchased? Or will having a port an extra 0.55" longer matter? :mooooh::gah:
- Calculate length of port needed
- Determine proper speaker & port placement before cutting any holes. The Precision Port should be placed at least one port diameter away from any inside walls, if possible.
- Trim center tube to 5" shorter than the calculated length.
- The Precision Port should be 1" longer than Lv when assembled.
