1 - 4 of 4 Posts
So I've been living out of boxes in anticipation of an upcoming move that's finally about to happen in the next few weeks. Once that's done I'll finally be about to hook up the new pre-amp (thanks again HTS!) and write a review. Till then, like any good shackster, I've been obsessing about the setup and logistics of everything.
So I've gone on ahead and flow charted out a wiring diagram for all sources, amps, network, and control.
If you see anything I've misses just let me know.
That's pretty cool.
I've never seen a set-up where the Pre/Pro goes out to the sub and the then sub goes out to an amp that then goes out to the L/R speakers.
But then again, I've not seen too many set-ups. :)
What kind of sub is that anyway?
I think you should throw a party when it's all set up and invite us to check it out!
Thanks. It's a Martin Logan Depth-i. It has line level in/out and LFE in bypasses crossover settings. So I'm passing my mains through the sub to the amp. This way I can blend the sub to mains and still utilize all EQ native to the AVR.
1 - 4 of 4 Posts
