1 - 3 of 3 Posts
Hello,
I am using my Presonus 24:4:2 digital mixing console as a soundcard with a macbook and OSX.
I have been trying to do a soundcard calibration in REW but I dont sem to be able to achieve loopback.
I can get the tone to playback via the firewire into the desk but when I patch the physical outputs to the channel inputs (1 and 2) REW does not detect any signal.
REW does not list Presonus Firestudio in the input devices so I have left it as default.
I would anticipate the response to be fairly flat anyway being a pro device but it would be reasuring to calibrate.
Any ideas appreciated. Cheers.
Unfortunately Apple's Java runtime has a bug that prevents Java applications accessing the inputs of firewire-connected soundcards. It might be fixed in Oracle's Java runtime for OS X. If the macbook has a line input that would work for measurement.
1 - 3 of 3 Posts
