Price of hiding wire in-wall?
9711 Views 15 Replies 12 Participants Last post by  moparz10
Hi everyone,
I just wanted to do a quick price check. So with the help of some of you guys, I have my 7.1 system (SVS speakers + HSU subwoofer), and now I would like to get people to install/mount the speakers + conceal the wire. I have 2 surrounds that will need to be mounted on-wall + 2 heights that will use ceiling mounts.
We got a quote from some local av people, and it seems like the price for doing this might end up being around $1000..... which feels on the high side for me. I just wanted to check with you guys before moving forward, is this reasonable?
Thanks!
1 - 16 of 16 Posts
IMO, that does seem pretty steep to pull wire. Have you considered doing it yourself and running wire behind the baseboards?
+1 for behind the baseboards, although doorways can be a problem with that idea. I have also pushed cables between the baseboard and the flooring.
If you decide to do it yourself, there is a very neat set of fiberglass pulling rods that I use:
http://www.amazon.com/Electric-Fibe...+electric+fiberglass+wire+pull+rods+fish+tape
Very nice and they work rather well.
This depends a lot on the job. I think I've had friends who have paid that. It all depends on the amount of time it's going to take and the degree of difficulty. Sometimes you don't really know what's in walls of people's homes until you get there. Obstacles like fireplaces, HVAC ducts and electric wires make things even harder. And I suspect your real problem is running stuff through your ceiling, which is always an adventure.
My wife and I have a general contractor who has helped me with this kind of work before and he's very good at it. Since he's a builder, he knows the decisions other builders do in walls that might make it difficult for a typical home theater installer. For example, when I needed speaker wire pulled to a left and right spots bordering a living room fireplace, it looked like a piece of cake since the wire just needed to traverse under the floor through an easily accessible unfinished basement. I'd done this before with other rooms. But the wall in question was an exterior wall that was oddly positioned on the foundation, likely because of the fireplace. I didn't have the experience to do the drilling without accidentally coming up at the baseboard, or worse, the hardwood floor. My contractor figured it out and the job was perfect.
If you've got a guy like that you trust (especially if he has experience doing electrical work), you might ask him. You might also ask some electrical contractors anyway...they may come in cheaper than the AV guys. Electric guys won't help you with speaker mounts, but most aren't hard to do yourself (except maybe your ceiling stuff).
Being an installer I can vouch for the 1K price tag....Most clients are of the thought that " its just running some wires in the attic "... Well if you've ever crawled around in an attic full of insulation you might have a better appreciation for the labor involved...Especially here in Texas where the attic temps in the summertime can reach 120+ degrees.... Added to this scenario ( you havent been specific here) is how many of the walls are exterior walls...It is much more tedious to drill and fish wires to an exterior wall if the roof line is on top of these walls ....or if any of these walls are adjoining to say bathrooms where plumbing needs to be found before any wires can be pulled....Although its only a 1 day job , its mainly the knowledge of the laborer involved in foreseeing and working through the unknowns - and there is ALWAYS at least 1 unforeseen problem that must be dealt with - 1 common example are fire blocks ( mandatory in all exterior walls in Tx) So my point is its always more than meets the eye with retro pulling 7.1 wiring....good luck with your new system and be sure to use a quality wire....:eek:lddude:
Hi everyone,
Thanks!
Hello,
At this point, Custom Installation is one of the few areas which independent AV Stores truly make a profit. With so many folks purchasing their AV Gear online, it is becoming rare to simply find an AV Store that offers AVR's, Speakers, Amplifiers, etc, on display.
Where these Rooms once offered such things have been repurposed into a single HT replete with Automation, Front Projector, Screen, Home Theater Furniture, et al.
If budget is tight, you might want to consider using a Handyman. While they certainly do not have the experience of Custom Installers, things like mounting Speakers should not present an insurmountable challenge. That being said, I am all for supporting local AV Stores as they are under tremendous pressure to stay in business on the whole.
Cheers,
JJ
That sounds about right price wise. I agree its sounds like a lot when you don't see a direct benefit from the cost. I must say like others said, if it was easy we wouldn't pay someone to do it. I would try the baseboard running of wires, as suggested, if possible. I remember a few years back a friend paid BB to run some audio cables and they charged over $1000 and did a pretty sloppy job (just punched a hole behind the tv in the wall and never even put a cable plug in the wall).
He's right...and it certainly can be harder than it looks. Another story with my contractor...six years ago I wanted to wire the entire house for CAT-5/6 Ethernet. The project was an offshoot of my kitchen remodel and as any installer will tell you, it's a lot easier to run cable when their no drywall. :) So the kitchen's wine nook got two Cat 5 wires and coax cables for future expansion all brought to a Leviton faceplate. I did the dual Cat 5 because I wanted the wireless router to go there (it was the most central location) but I needed two wires back to the basement...one for the cable modem (WAN) and the second (LAN) back to the main switch. Since the basement is open, it's pretty easy to get all of the rooms on the ground floor wired (save the living room, which I discussed earlier).
The hard part was the second floor bedrooms. My house is about 20 years old and I wanted some way to string at least one and preferably several CAT-6 wires to the attic where then we could run lines to the walls of the three bedrooms plus an additional one to replace a hard phone line, and two more for future expansion. But where is a good place to run the wire? Outside up the main wall on the side of the house? That was possible but I wanted to remove the existing coax wire up the side of the house since I was dismantling the satellite dishes. The kitchen renovation revealed a way to do it on an inside wall right next to where we were running wires for the wireless router. The hard part was breaching the wood between the floors of the house.
This is where having a contractor came in handy (and FYI, this same contractor did my kitchen renovation). We figured the place where we needed to drill an access whole was behind a wall in the master bedroom. So he cut out a small piece of drywall enough to see inside and get a drill in. After measuring where we thought the hole needed to be half a dozen times, we drilled the hole and then did the same thing in the attic above. Then we dropped a weighted string line starting from the attic, through the hole between floors and finally through the last hole drilled between the ground floor and the basement. The measurements were good enough that it wasn't long before we got the line fished through.
Then we tied the fish line to a a rope made of the nine CAT-6 cables we wanted all wrapped with duct tape. It wasn't easy getting the rope through the holes (especially with the smallest between floors) but we got it done. The rope of CAT-6 had every line premeasured for 100 ft (the limits of the Ethernet standard). Once in the attic we had enough extra distance to get to every place we wanted...well, almost every place. We were unable to run the line to the outlet in my son's bedroom due to some kind of obstruction in the wall...most likely an attachment point of the home theater room structure which is adjacent to it. Since it wasn't a huge deal to have a working line in that room, we decided not to waste valuable time there.
The last job was the close the opening in the bedroom wall (before my wife saw it!). My contractor patched up the hole and repainted the wall in a way that I can't tell where the hole was to this day. His work is incredible...far better than if I'd tried the same thing. After that it was just patching the cable to some Leviton faceplates and I was good to go.
I gotta say... IF you have carpet, then run it down the wall, remove your baseboard, make the appropriate holes and notches and run it under the baseboard.
If only Tesla was tuned into this thread. He would have us beaming all those signals around. Some day.
I would end up trying it myself, following baseboard and carpet suggestions. Fishing vertically inside walls can be done - if you've been living right and have some "luck" points saved up. But one little weird obstacle somewhere can be a showstopper. Definitely an occasion for calling on a buddy or two. Get a good stud finder.
On the other hand, as with car repairs, it can be nice to just let someone do the work and write the check. I would never turn such a job over to someone I didn't really, really trust to communicate well and do top-notch work. And would go trusted handyman over unknown AV or contractor crew. The $1K price tag is not a huge surprise. Getting it done in one day would be less a priority than the quality of the finished job - I don't mean more billable hours necessarily, just allowing for the unforeseen and a possible delay.
Best of luck!
If you have attic access, it’s not too hard to run the wiring yourself. There’s a link in my signature with detail instructions on how to do it.
Enjoyed your story, Sevenfeet! :T
Yup, two-story houses can be a challenge. We got lucky with ours; there were enough little attic spaces here and there to access the places on the first floor where we needed to get wires to.
One location in particular was a challenge though, for the rear surround speakers. I decided to bolt them directly to the wall, which required bringing the wire out the wall from directly behind them. The problem was that the preferred mounting location was directly between the floors! IOW, it was above the ceiling of the first story, but below the floor of the second story!
The finished product looks pretty neat, like the speakers are just floating up there with no visible means of support, but it was certainly the trickiest rear-speaker install I’ve ever done!
Room Wall Material property House Plaster
Ceiling Light Architecture Daylighting Room
That's very clever. How are you suspending the speakers...by exposed screws that you are hanging the cabinets from or some other method?
I've always wanted to add some wall mounted surrounds to make my 5.1 system a true 7.1 but I already know that the construction issues of my home theater walls are ugly (but not impossible).
LOL, left that part out, didn’t I?
What I did was take the drivers out of the cabinet and shot three or four long #10 screws right through the back panel and into the wood behind the sheetrock. So basically, they're bolted straight to the wall.
When doing something like this with a speaker, there’s a structural concern – namely that the cabinet is probably held together with glue and staples and wasn’t designed for the back panel to support the entire thing. I mean, there’s a chance that the whole thing could come crashing down, save the back panel which is securely attached to the wall. So, I installed internal “L” brackets between the rear panel and the top, bottom, and side panels. Worked out well, because no sooner did I have the speakers mounted, our cat discovered that they made a nifty up-high perch for surveying his kingdom. :)
It's easy if you have a basement as well......well sometimes it depends on how your house is built haha!
Now that's thinking outside of the box! Or I should say within.
1 - 16 of 16 Posts
