1 - 8 of 8 Posts
Plain ole user
Which inputs, which types of signals, menus and PIP affected, etc? Post an image? Not much to go on in your post to suggest anything.
The TV starts to flicker as soon as I put it on. At first it was on top put now it has progressed to the whole screen. You can see the picture but it sort of eratic, colors are ok.
Pls. help
Plain ole user
Can you post an image? Is the flicker in brightness or in sync?
Plain ole user
My guess would be maybe bad caps in the hyper module.
Plain ole user
IF it is the hyper module problem, there is a thread about it that includes some specific information. It can be a tricky repair, as it requires removing surface mount caps that give many people problems damaging the circuit traces.
1 - 8 of 8 Posts
