1 - 5 of 5 Posts
My room is 12.5x19. My concern is that someone sitting in the first row could block some of the image with their head. What parameter in a projector can I check before purchasing one?
I'm still contructing, but I think the heads of the first row will be at around 13ft if that helps...
The projector lens will be at around 19ft and probably around 85-90" off the floor.
Even easier... take a corde or something similar and trace a line from the expected projector lens location to the lowest part of the screen, and see if the heads interfere.
You'll also want to check the projector's maximum vertical screen offset. That is how far up/down the projector can be positioned relative to the screen. Some have fixed offset values that greatly restrict projector placement. For instance, a projector with a very large vertical offset may require too high a placement for a large screen in a room with a low ceiling. I'd look for a unit with adjustable offset.
Agreed. I got lucky, and bought one with an adjustable vertical offset. When I first plotted out the room, I did not need it, where I thought I was going to place it. It turned out I needed to wall mount it in the back...:gulp:... Thank goodness I had the adjustment capability, it all worked out perfectly
1 - 5 of 5 Posts
