I've been teasing the idea of getting a projector myselfand my budget was close to yours. Was looking at the Epson 8350 as a suitable choice, but my needs may have been a bit different... it would be in a small room so I needed a good short throw. Juat an idea to throw oout there, but good luck finding what u want.
I'd seriously recomend a dlp. Ive seen a few new lcd pj's and they just cant hold a candle next to a dlp. To be honest, the only dlp's i have seen were mitsubishi (hc3800, hc4000) so i cant recomend any other brand really. I have an (old) hc 1100 that i bought off ebay for $500! A friend has an new epson and he reccons mine is heaps better! Its the contrast that cant be beat!!
I keep reading about "rainbow" effect with DLP - not quite sure I understand the effect? One or two posts seem to indicate that some people see them..others don't?
The rainbow effect is caused by the colour wheel being too slow. I had an older dip that had a 2x colour wheel and the rainbows were noticeable but still not mood breaking. My hc1100 has a 4x colour wheel and the newer models I mentioned have 4x and 5x colour wheels. I've had many movie nights (obviously) and no one has said anything to me about any funny rainbows. I can't see them at all with my dlp. Even so, the contrast is more than enough to make up for the occasional rainbow. I demo'd the latest 3d Panasonic in the shop the other day (sorry no model number) and it just looked flat and lifeless. The blacks were poor and the dynamic iris was terrible!!
I'd say that noticing rainbow effects are quite rare these days so get a dlp!! I'm pretty sure the mitsubishi's are a better pj from all the reviews I've read so stick with them!!
There are a number of us here who use the Panasonic AE4000u and should be able to get one for around $1500. Im not sure about the "poor black levels" as im thrilled with mine and the blacks are great.
DLP are also a good choice but if you like watching a lot of movies the auto aspect ratio zoom of the 4000 cant be beat. I use a 2'35:1 screen and would never go back to 16x9 (1'85:1)
...but if you like watching a lot of movies the auto aspect ratio zoom of the 4000 cant be beat. I use a 2'35:1 screen and would never go back to 16x9 (1'85:1)
I've already got an Epson 8350 - too good of a deal to pass up for a first projector.
I'm just starting to read about 2.35:1 ratio...so not sure if my Projector will do that setting? I'm thinking it's a moot point anyways as I don't have the room to make my screen wider and for the 16x9 movies, definitely want to max out on the height so maybe for my Theater 2.0 down the road?
Any recommended comprehensive posts on this topic (screen size/projector settings etc)? I'd like to understand it better...but again, I'm think I'm stuck at a 5x9 screen size.
2'35:1 is on probably 85% of movies now a days. its where you have the black bars on the top and bottom. The Panasonic is the only projector that does this automatically however if you have the Epson set up far enough back you can manually do this by just zooming out.
But given my width is maxed out...to go to a 2.35:1 ratio sized screen would mean sacrificing the height for all the 16:9 stuff - IE: I'd end up having black bars on each side of those movies instead....and the height would be shorter to boot.
I did the math quickly. with my 5'x9' (16:9) screen, 2.35:1 movies will be the full width (9') and 46" tall. I can live with that - given the max height on my 52" TV was only 25" for 16:9 media and a measly 19" tall for 2.35:1 stuff!
I still do like the look of a 2.35:1 screen though...
The Rainbow Effect should not be a problem with today's PJ's, but I can show you what the effect looks like since my PJ has it is spades! Read DLP Rainbow effect demonstrated.
Black levels and 'real' contrast are two different things. With a dynamic iris (which physically restricts light from the globe) you may have a black background which would trigger the iris to shut. As soon a light image ( like credits or movie title) comes into the black the iris opens to achieve the bights needed and your black becomes lighter as well. A good test would be ratatouilli. Near the start where he's eating the strawberry and the cheese together. I hope this makes sense haha!!!
I have dynamic iris turned off and black levels are still great. My room can be made pitch black so I can tell. is it as good as DPL no but its not by any means bad. I do run my projector in eco mode so that may make a difference.
Hi, I have a Dell 1800MP projector with very few hours on it but it had the 3300uF 10V power supply cap failure with blinking orange LED. After replacing the capacitor, things looked better at start up with the on-off button blue and all the other controls lit up blue, but after 1-2 min, the...
Two of my passions have merged. HT and Golf. I've recently purchased an Optishot 2 golf simulator. I'm totally addicted and have a "range" set-up in my garage. I now wish to make the jump into projecting the course onto the golf net. This presents some unusual challenges. The net will be about...
Well...where do I start?
Just fired up my brand new 5050UB. Very disappointed and underwhelmed to say the least. Maybe I expected too much, and my bar was already set very high with my trusty Panasonic PTAE-80000U.
The 4K videos look no better than standard Blu-ray movies. In fact, the Panny...
Optoma's CinemaX P1 4K UHD/HDR Short Throw Laser Projector is scheduled to launch in the USA on September 15, 2019.
Here's the .pdf spec sheet.
Optoma states the peak luminance at up to 3,000 Nits. 4K refresh rate is 30Hz and the CinemaX P1 uses TI's .47 DMD DLP and an eight segment RGB color...
Hi all, I'm looking to get my first projector for a living room. I read through the guide in the sticky section. I have NOT bought a projector yet :)
My living room is basically square but open on one side. It's about 15ft from one wall to the other. It has a few windows and there is ambient...
