1 - 12 of 12 Posts
I am wondering which projectors (especially budget 720p models, if any) have the built-in vertical stretch feature, for doing CIH with a lens models from HTB or Aussiemorphic ?
Thanks ! :bigsmile:
John
John,
The three Brands that I would recommend that have VS are..
Optoma.
BENQ.
Sony.
I think most if not all models in those brands have VS..
I would add the Panasonic also. But you don't want to chose a projector based on VS only. Ready reviews!
How can you get VS with 200-300 $? Pls elaborate.
VS is VS. The image is scaled (streched vertically) in order to then accomodate an anamorphic lens.
There are 3 common ways to obtain VS:
1- DVD player
2- Projector
3- Video processor
I believe you confused a lens with VS, and I believe you meant 200-300$ for a DIY lens :).
Yeah, but what about 1080p resolution?
G
at 1080p I know personally the BenQ W5000 has it (I don't use it but have turned it on for laughs). and its reasonably inexpensive too.
1 - 12 of 12 Posts
