1 - 16 of 16 Posts
I am getting ready to buy all the "equipment" needed to check out my speakers and integrate an IB subwoofer. I plan to get a Sound Blaster live external USB card for my laptop and a BFD. My question is about mics and SPL meters. I am new to this and it is a bit confusing. Could someone explain to me the pros and cons of the ECM8000 mic and Galaxy CM-140 or CM-130 SPL meters? Is there any other support equipment required with either one? I assume the SPL can be used by itself to check sound levels while the ECM8000 needs to be used with a sound card and PC to read a sound level. (But it is a lot less expensive) Do both do a similar job for the whole frequency spectrum of 15hz to 20khz? Is one easier to use than the other?
Thank you.
Hello Dave,
The CM-130 SPL meter does not have a line output and thus can not be used with REW or any other software that requires the direct hookup to the SPL Meter. The CM 140 is the best low cost option for a meter as the radio shack meter is not accurate above about 12,000Hz and has some issues below that.
The ECM8000 is a good mic but as you still require an SPL meter your spending allot more than you need to.
REW needs some sort of reference point to know what is 75db without a db Meter you would have to guess and thats not always the easiest thing to do.
I read somwhere that the ECM 8000 is more accurate and extends down to 15 Hz but the SPL CM-140 is only speced to 31.5 Hz. I too am embarking on the mission to REW my system (and to boldly go where no WAF has allowed me to go before)
Yes, this is true. but you need to spend a fair bit more cash if you go the ECM8000 route.
Im a bit confused after reading some of the basics on the REW site. Can someone clarify please before I go out and make a SPL meter purchase.
I intend to use REW in a recording studio where I have access to microphones and preamps.
The REW site says: "Alternatively, a microphone (with preamplifier to produce line level) may be used to make measurements, but an SPL meter is still required to provide a reference SPL figure against which to calibrate REW's SPL display."
Does this mean that I can use any cheap SPL meter to calibrate my studio microphone for use within REW?
Can I purchase the cheaper CM-130 instead of the more expensive CM-140?
Thanks!
· Super Moderator
A meter really isn’t necessary to take REW measurements. When doing the SPL calibration, just run the test signal at a comfortable level and “tell” REW it’s 75 dB. The graphs generated will show accurate frequency response, even if the actual dB level indicated at any specific frequency is incorrect.
1 - 16 of 16 Posts
