1 - 10 of 10 Posts
Panasonic PT-50lc14 50" HDTV
I installed the new lamp but how do I reset the meter so that it doesn't pop up every time I turn on the TV
I do not have the original remote if that maters.
Thanks for the help
Plain ole user
You may need to get a remote.
From the Panasonic Service manual:
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds in
power on condition.
Ok I gave it a try but nothing happened
I tried both buttons circled below but neither one worked
Plain ole user
Do the controls operate the set?
Plain ole user
Did you unplug the set?
Plain ole user
My experience is that when the procedure that is defined by the manufacturer does not work as expected, there is usually a timing or sequence issue at play. Try varying the timing of pressing the buttons on the set and remote.
hi ken2here....i read and tried EXACTLY all the steps you mentioned but will not reset
any other suggestions ?? i do have that brown strap attached not sure if it is set correctly
or if that could poss. be the problem...please advise...tu
1 - 10 of 10 Posts
