1 - 3 of 3 Posts
A friend of mine is only able to use a pull down screen in his room and I am hoping to get advice on the best choice. His room has decent light control and he will be using a JVC X35 about 14' away from the screen mounted on the ceiling so I don't believe brightness will be an issue. His walls and ceiling are lighter colours so that is not ideal. So far I am thinking the Da Lite HCMW or the Elunevision Triton 1.2 mat white might be decent choices. I am uncertain about waving with either of these choices so if anyone has some better options I would appreciate your advice as well as whether either of the choices I have suggested has advantages over the other.
Thanks for your help.
I went with a "high power" DaLite pull down and have been real happy with its performance. It might just be my particular screen, but I haven't had any deformation issues (don't have the tab tensioned model but it is available from DaLite). The screen is super bright though a bit directional, however, it's not nearly as directional as a regular beaded glass screen. My only issue with it is cleaning which must be done very carefully or it changes the reflectivity slightly.
Here's a source I've used with good results: http://www.projectorzone.com/T:Screens/M:Da-Lite
1 - 3 of 3 Posts
