1 - 12 of 12 Posts
Table saw works really well.
I use a handsaw.
Marking up....
A simple way to get 90 degrees is to roll a piece of cardboard around the pipe. When the edges of the cardboard line up, mark around the pipe with a pen
For shorter ports, you can ensure the ends are parallel....
I often us a mitersaw and place the PVC firmly against the rail and spin it towards the motor (using Collo's method would be very helpful to ensure accuracy).
Another method I use most often is to use a band saw.
I sketched up my jig, a circle is routed in the deck just slightly larger than the tube's outer diameter. The deck is clamped at a right angle to the tube and set with large worm gear clamps - not drawn, but you get the idea (hose clamps ).
The router's depth is set to coincide with the placement of the deck (say 1/2" down on a 3/4" deck), and a spiral up-cut bit is used to shave the end of the tube. Sweeping passes with the spinning up-cut bit over the tube. The cut into the tube's end will end up being 1/4" inch taller than where the bottom of the deck sits relative to the tube.
1 - 12 of 12 Posts
