Yes, it can be but its output in Bridged mode is still only about 1200wats into 4ohms min. if your driver is lower than 4ohms you wont be able to use the amp in bridged mode and then you only get 600Watts into 2ohms
Is there anything better than the CX302 for a sub-woofer amp that is around $120? (it can be found on eBay for about that much)
I'm thinking of buying the CX302 because it is not as loud (I have heard a CX404 and it is quiet) or old as the others I've been looking at RMX850 etc.
Just curious, it has an input impedance of 6K ohms (unbalanced) but almost everything else i have seen has 10K ohms input impedance.
Is that a bad thing or is it just fine and I don't need to worry about it?
