Quad RL-P15 build SLLT: Is 1 1/2" MDF needed?
1795 Views 9 Replies 6 Participants Last post by  looneybomber
Hello Shack;
Is 1 1/2" MDF needed for the cabinet if I use 2" X 2" wood for bracing in a grid of 1' on all the panels and 3" thick facia for the woofers? Is this overkill??
Also what about panel bracing on the outside of the box. The box will be in an adjcent room out of view.
Thanks
Jujuman
1 - 10 of 10 Posts
What are the dimensions of your box? I don't think you would need to go to 1.5" as long as it is properly braced, but I'm not the expert on SLLT. Sounds like a wicked project though!:devil:
Hey THX;
Basically it is a copy of Rodney's sub @ 8' X 3' X 4' (70 cu.ft internal) tuned to 11.9 Hz.
Jujuman
Hey THX;
Jujuman
Cripes!
Is there a link for Rodney's build?
1 1/2" on the facia and 3/4 for the rest is fine. I'm not sure what you mean by 2" X 2" wood for bracing in a grid of 1'. It would help if you could post a drawing to make sure we understand exactly what you mean.
Hey Mike P;
The bracing will be "window pane" type running both ways on each panel to ensure the box doesn't vibrate.
Jujuman
1.5" on the driver baffle(s) is fine, along with .75" walls, assuming enough bracing is used. For a sub enclosure, tight matrix style bracing is overkill, but any unbraced surface longer than 1' long is insufficient IMO. So, for huge enclosures, a spaced out matrix brace may be necessary...but it really all depends on the how high you intend to cross them over.
Also, exterior scrap 2x4's can work good.
Another thing that can help is the use of push/pull or push/push style manifolds where the driver's vibrations cancel out.
1 - 10 of 10 Posts
