The signal is basically in the noise at that point. When the meter calibration file applies it's inverse compensation, it makes the signal appear to rise. Note how the noise signal flattens just as the meter cal file flattens?Why does the freqs below 10hz start going up?
I am using Aperion 5Ts, 5C and the subs are Epik Tower and Epik Dynasty. Audyssey does have some sub equalization and some people think it works really well and others say it sucks.Wow, that's pretty awesome results. What sub and front speakers are you using btw? I guess you can forget about buying an equalizer for the subs. Does Audyssey supports subwoofer equalization?
Well from the looks of it, it sure does look like it's working good for you! Nice response on those charts! Have you tried graphing it with audyssey turned off? Just to compare.I am using Aperion 5Ts, 5C and the subs are Epik Tower and Epik Dynasty. Audyssey does have some sub equalization and some people think it works really well and others say it sucks.
