1 - 5 of 5 Posts
Hi,
So with some help from the forum (thanks tons guys) I have spec'd out my sub and box. I need a subsonic filter at 18hz. The prob is my amp does not have a subsonic filter : / well, not an adjustable one anyway.
Question is where do I find what I need? I've searched but can't find one that goes that low. Maybe, I'm searching for the wrong thing. Can someone help me out here?
Thanks
Then you won't be needing the Reckhorn B1. The Bash 500 from Parts Express has a factory set subsonic filter at 30 hz which is too high for your needs. It can be modified by changing 2 resistors. Change R17 to 20k ohms and R18 to 75k ohms and you'll get 1 db of boost at 25-30 Hz and a SSF at 18.7 hz, which is close enough for what you need.
http://www.partsexpress.com/pdf/300-752.pdf
1 - 5 of 5 Posts
