For those who like to be perfectionists and like to do it manually and have a little control: The ultimate subwoofer parametric equalizer: Very easy to use with Avia or DVE and a SPL Meter.
Rane PE 17 Parametric Equalizer. Seperate in and out gain controls, sweepable Low Cut (subsonic filter) is 10 Hz to 250 Hz, 12 dB/octave Butterworth response. 120 dB (20-Bit Equivalent) Dynamic Range. All five parametric bands are identical and offer 100% overlap. This allows the PE 17 to be configured one time as a 5-band subwoofer parametric equalizer, with all bands covering the range of 10 Hz to 200 Hz, with each band covering five separate parts of the audio spectrum — anyway you want it. Additionally, you may vary each filter’s bandwidth from as narrow as 1/30 of an octave to as wide as 2 octaves, and adjust the Level over a boost/cut range of +12 dB to -15 dB. The extra-deep cut range, when used with a narrow Bandwidth setting, is effective against troublesome feedback frequencies. Specially designed circuits make all these adjustments completely independent. To you, this means the ability to change all controls in any order without affecting the others. balanced/unbalanced designs XLR and ¼" TRS connectors. Also have gold plated ¼" TRS to RCA adapters. Rack mountable. Separate bypass switches with LED indicators provided for each band. $250 Buyer pays shipping. http://www.rane.com/pe17.html
