1 - 1 of 1 Posts
Plain ole user
This will tell you a lot about convergence problems, but be aware that your set does not use output ICs. It has discrete components and the problems are usually in the convergence supplies. If you have a true halo, it may be a coolant problem or a focus problem. Fuses, IIRC, are on the deflection board near the flyback, but if one is open it is likely due to another problem.
http://www.hometheatershack.com/for...based-rptv-convergence-repairs.html#post43725
1 - 1 of 1 Posts
