I've pulled an older 5.1 RCA receiver model RT2250 off the shelf (10+ years storage from friend), with the intention of setting it up for my father-in-law. He's in his 80s (his wife also) and they're struggling to understand the factory speakers in their TV.
Anyway, I know it's not a fancy unit, but for the intended purpose, should work quite well.
My question to anyone who has run this unit in the past: the "main" heatsink runs along the front side of the unit, and stays nicely cool. However, there is a heatsink in the middle of the main PCB near the power supply that runs fairly warm. I've added a nice black finned heatsink with proper grease and support, as well as re-flowed the solder as needed (which about half of the transistors did in fact need).
I know those transistors are bound to be running cooler then they were, but there is still a nice bit of heat generated, and I'm curious as to whether this is a normal situation, or if it should be running cool, and I'm not addressing the actual issue.
I currently have it set up on the coffee table, and have run it many hours each day for a week - it's running just fine (as it was before adding heatsinks)
Thoughts and experiences?
Thanks, Joe
What speakers are you using with the receiver? do you know the ohms rating on them?
Audio Source LS 300 8 ohm for fronts, and I've had a Bose 141 in the center position.
Sony 6 ohm passive sub.
Receiver calls for 6 ohm min for all but the sub, which calls for 3 ohm min.
Now, interesting the way Bose specs their 141: "Compatible with amplifiers and receivers rated 10 to 80 watts per channel; rated 4-8 ohms"
Which means exactly what? That the receiver should be 4 ohm capable?
So I've just switched the Bose out for a cheap Panasonic 8 ohm from the "test speaker" pile - don't detect any difference in heat generated so far (10 min running).
And as far as "heat", it no longer smells like hot electronics as before the addition of sinks, and I "test" the heat by placing my face close down to the top.
It's warm, producing heat, but it's not a "room heater" by any means (as I've read folks describe their Onkyos)...
I would not worry about it, some heat is very normal for an amp to produce particularly A/B switching amps that are normally used.
But yes, if that Bose is 4ohm it would be putting a bigger load on the internal amps of the receiver. If its not rated to drive that simply dont push it too hard.
Well alrighty-then - a second opinion is always nice.
I'll keep running it as our TV sound for a week, and if all is well, then well enough :)
