1 - 5 of 5 Posts
I've taken the woofers from several broken ART200's, and Wanted to make a subwoofer-wall (haha, dj & an engineer, I need this)
But I cannot find the technical specs for the drivers anywhere!
All I know so far is:
It's official replacement part is: L12-ART 200A/AM
Frequency Range goes down to 50Hz @ -1-dB
Frequency Response goes down to 70Hz @ -3dB
It's a 12 inch driver
And that's everything, I'm just trying to figure out how low they can go, and whether they'd be suitable as subs, and hopefully find enough info so I can model them with WINISD.
Thanks for your help guys
Super Moderator
Any of the RCF 2 way design use a Pro Audio driver that is good at 40hz and up. SO if you are planning on a subwoofer design for 40hz and up it can be possible with a 15 but not much with a 12. If you have a LOT of them then maybe be able to build a 40hz subwoofer .
That doesn't really narrow anything down for me mate..
Haha, any cahnce you could give me something a little more specific to go off of?
Without T/S parameters your guess is as good as mine. All you can do is experiment with cabinet sizes and tuning frequencies.
Any pro audio driver that was designed for 70Hz @ -3dB is not going to have the excursion capabilities for sub woofer duty. Just my opinion.
1 - 5 of 5 Posts
