That would be interesting ...but the TV needs to get just the center speaker audio signal, if it gets all audio from DVD it will sound funny (I've done that, use the TV speaker at the same time with the surround sound and I didn't like it ....) :yes:The TV is also able to act as a center but I need to read up on that, maybe try it.onder:
Yes, that works just fine for the interim. I did if for a while a few years back and the one nice thing is if you want the dialogue a bit louder or softer you can independently adjust it with much more ease then using the receivers menu. Make sure you either use a "Y" splitter or just use the left input on the back of the TV as that automatically should select mono for that input.The TV is also able to act as a center but I need to read up on that, maybe try it.onder:
That may be a good question to start a new thread for.Can anyone link me a source showing Brown Burr to be superior to Cirrus Logic? While that statement is thrown around a lot, I haven't found much in the way of hard support. The best I could find were some numbers showing a better SNR in favor of Brown Burr (120 vs 114) which would be hard for a listener to distinguish.
Its been done hereThat may be a good question to start a new thread for.
Yes, the 806 is 14lbs lighter than the 805. Thats a substantial drop and cant be good for build quality or sound quality.Tony... didn't you also learn the 06's were much lighter than the 05's, which might lead us to believe they may have reduced the power supply?
What about emailing Onkyo and ask them (if you're lucky they will give you the reason) ...just tell them that you own the 805 and were planning to get the 806 and you saw that differene in weight and are wondering why??? :huh:Yes, the 806 is 14lbs lighter than the 805. Thats a substantial drop and cant be good for build quality or sound quality.
