1 - 10 of 10 Posts
Hello!
I'm deciding to buy Onkyo TX-SR805 Receiver.
As i live in europe, i found on internet, that if i buy Receiver in USA (which would be a lot cheaper), i could meet:
1) power supply problem (could be solved with transformer)
and
2) FM frequency stepping differences (could be solved, simple not using receiver radio, or by buying some external radio).
I wonder, are there any other problems i could meet?
Also i need some information about USA version of Onkyo TX-SR805 handling with PAL system.
Thanks in advance!
Hello and welcome to the Shack,
You say that buying the 805 in the US is cheaper however once you factor in shipping it to you and the cost of getting a good sized transformer for the power conversion are you sure your still better off buying it from the US?
OK, i've found on the Onkyo web site, one company that represents Onkyo here in Latvia.
I've called them and asked the question about USA/EU technical differences.
They coul'd say anything else, then: "you can buy it where ever you want, it will be your problems" :explode:
1 - 10 of 10 Posts
