1 - 4 of 4 Posts
I'm just looking to screw around a bit, and build a pair of home theater speakers. I already have some TI Class-D modules, and a mini-DSP with 5 channels. I'd like some good recommendations (in 2021) for a cheap, but quality 2-way build. I have a set of dedicated speakers that are not really HT material.
These will be paired with an SVS PB-16 subwoofer.
Thanks in advance.
Cheap is relative, what kind of budget?
There is no budget. Cheap is relative to the cost of components, not personal wealth.
Something that sounds amazing, and costs very little. In absolute dollars. ;)
I'm currently looking at the Amiga MT (minus crossovers, making way for the active)
One of the best bang for the buck is a MLTL done by XRK member at DIYA.
Easy build, easy XO components, and quite stunning.
A MLTL will sound so much better than a simple BR, well, YMMV, but to me they sound so much better and controlled.
The design started as a 2-way monitor, then evolved as a MLTL because of the love we have for MLTL ! :)
Check it out!
The first post holds the evolution of the design, to the MLTL
1 - 4 of 4 Posts
