1 - 11 of 11 Posts
Hi All,
Could some one recommend me a USB sound card for my Lap top,
Every time i try to calibrate my sound card REW says it has clipped, though i am using my radio shack spl meter as the mic.
To be honest i do not know what i am doing but i will try my best.
I have the BFD 2496 and i have been playing with it to get my head around the peq,frquency and bandwidth controls do i need the midi adapter as i think it is quite easy just inputing manually.
Thanks in advance
Do you have the RS meter plugged into a mic input? If so, that is your clipping problem, the output of the meter is line level. If your laptop has a line input use that, otherwise look at basic USB soundcards like the M-Audio transit or the SoundBlaster Connect (but beware the SB appears to be XP only, not Vista). Manual entry of filter settings is fine once you are used to it, don't have to get a Midi adaptor.
I no longer own it, but I think the M-Audio Audiophile USB has the features you are looking for. (Please don't take my word alone on this. It has been a while).
If I were using a Behringer EC8000 mic connected to a mic pre amp could I then connect it into the laptop microphone input ?
No, the output of a standard mic preamp (such as the Behringer XENYX 802) is line level. You require a line-in.
Some of the better external USB soundcards (such as the M-Audio products) have a mic preamp built in with phantom power. These connect to a laptop through USB and then the external soundcard has line-out and a mic-in for the ECM8000
And the M-Audio Fast TrackPro includes a midi port to upload your filters values to your Behringher EQ !
I bought a Creative Labs SoundBlaster MP3+ External USB Sound Card on ebay that was refurbished by creative. I payed $14.00 and it shipped in a couple days first class mail for a total cost of about $20.00.I decided to disable bass boost and I had to disbable the input for line-in with the included software.
I would recommend one for a person on a tight budget. Here are the measurements with a -12 dB sweep.
1 - 11 of 11 Posts
