21 - 35 of 35 Posts
Discussion Starter · #22 ·
Ok guy's I'm back here's little back ground I wasn't to clear about somethings my bad. I am looking for a receiver to match up with 1 of these 2 sets of speakers
1 SCS-01m 5.0 with sbs surrounds with PC12-NSD
or
2 STS 5.0 with sbs-01 surrounds with PC12-NSD
The room that all this is going into is shaped like the letter I Front&Back w 7'.2" Middle 6'.1" Length 14' Ceiling height 9' so my request is as follows so I stick with the Pioneer vsx-21txh or look for something else all together I know this may seem like reliving the past, your patience and advice I will need in order to make sure I get the most out of my HT experience thank you to all who have posted in the past and to those who will post.
Hello,
I would go with an Onkyo TX-SR706 for around 400 Dollars if still available. Accessories4less and ShopOknyo both seem to offer them.
THX Certification and Processing Modes, strong amplifier section and used to retail for 900 Dollars.
Will make an excellent AVR for your SVS's.
Cheers,
JJ
Discussion Starter · #24 ·
Hello Jack,It never fails I always expect to see you as the first reply always nice to hear from you again. So ditch the Pioneer and go with Onkyo 706 thanks Jack.
Hello,
Both are good receivers, I personally prefer Audyssey over MCACC. It is great both are TXH Certified.
The VSX-21 is a solid receiver and weighs almost 40 pounds. The VSX-1019 weighs under 20 pounds and goes far to explain why the 1019 output under 30 watts when all channels were driven. The VSX-21 is a much better unit than the 1019.
If you prefer the sound of the 21, by all means go that way. With the SVS PC-12 handling your bass, either receiver will be quite able to drive the SVS's especially when relieved of handling bass duties.
Cheers,
JJ
Discussion Starter · #26 ·
Hello,
Cheers,
JJ
I want to understand so bare with me, A receiver has its own sound as well, I have read a few things on Audyssey and MCACC on other forums but it always breaks down to a flame war and not much is explained and of course I'm left in the dark.:scratch: would be so kind as to tell what the difference between these 2 and what makes one better than the other in your opinion.
Hello,
It's late so I will keep it short. Audyssey works wonders on the Subwoofer Channel. MCACC is not active below 60 Hz or so. So with Audyssey, you get full frequency Room Correction. I have just had better experience with Audyssey and you will see many AVR Companies use it.
If you are fortunate and have a good sounding room to begin with, then Room EQ is not that important.
However, most are not so blessed.
Cheers,
JJ
Thank you Jack.
If you get an AS receiver make sure you do the measurements in a 8 position grid around the primary listening area. If you'd like some help let me know I've done AS(Auddysey) calibration successfully numerous times.
Selecting a receiver is simple. Just get one with the features you want and move on. Most amps handle 4 ohm speakers just fine. If you have a problem(very unlikely) just let us know.
I buy receivers purely on looks/features.
All I need is HDMI repeating and Pre-amp outs.
So I got the cheapest receiver that has both. The HK AVR 247. It works just fine for me and only cost 200 bucks. That's how simple getting a receiver is. Spend your time on the speakers not the receiver. :bigsmile:
Discussion Starter · #30 · (Edited)
Thank you Isiberian, see I like this simple answers, so an AS receiver has the ability of multi-position calibration vs MCACC which is one position. To Jack's point earlier I am not blessed with room acoustics when my daughter lets loose with her head splitting screams in this room the reverb seem to go on forever. So I guess Auddysey will help in toning it down were as MCACC will not do have this right
I am with Jack on the Audyssey over the MCACC in the pioneers. I've experienced both and the Audyssey just seemed to do a better job and was more pleasing to my ears.
Also another point, you mentioned the screams seeming to go on forever and ever, any auto calibration will help tame peaks in the frequencies, but you are going to want to do a little bit to tame that physically as there's only so much that the auto calibrations can do. In fact, if it is a really echo-y room, that could hinder the auto calibration, too.
Discussion Starter · #33 ·
Maybe you could enlighten me a bit, the room has hard wood floors and the walls are plaster which are bare,and it's shaped like the letter I. so any advice on how to tame this room on the cheap.
I would cover some of the hardwood floors with a rug or something directly in the line of the speakers. Bare walls, even pictures or decorations can break up the sound a bit. These are simple ideas if you don't want to put acoustic paneling into your room.
Discussion Starter · #35 ·
I have no problem putting acoustic paneling in this room, The wife has the rest of the house but this room is mine. I just ask for on the cheap for a temporary measure till I can buy the right stuff.
21 - 35 of 35 Posts
