I'm looking for recommendations for a decent IR (infrared) keyboard with a build in trackball or other mouse emulating device. The reason why I'm looking for IR instead or radio is because I would like to be able to teach my universal remote some of the keys. Makes things a lot simpler instead of having to run seperate software to recognize a remote, etc.
I've looked into Addesso keyboards, but apparently they use two transmitters which means you can't teach a learning remote any of it's codes. The best I have found so far is a few keyboards from KSI, like this one for example: http://www.pckeyboards.com/products_detail.php?product_id=33 . I haven't found any reviews or comments about it though. If anyone can recommend a decent IR keybaord with build in trackball (or other mouse emulating device) that a universal remote can mimick please let me know about it.
Thanks,
Harry
Thanks,
Harry
