hello again everyone,
what amp would you wisely recommend for this setup?
-Stereo 2.0 with two KEF R900. Mostly for music listening (all genres)
-They are hooked meanwhile to an Onkyo TX-NR709. But I can use it as a pre-amp, this one have pre-out for 7ch.
- listening distance 12-15ft. Big living room 17x14x11 ft.
i contacted emotiva and they suggest me to buy two XPA-100 (rated 250Watt @8ohm THD<1%). I like them because I'll have channel separation, plenty of power I guess, and right now are 359USD each.
but of course I want to have a second opinion with you. the idea is they manage the full range since there'll be no bass for now.
Appreciated any comment.
None. Use the surround channels on the Onkyo to power the terminal for the highs. At 6 ohms ( the KEF says 8 ohms but use a multimeter and put it on the terminals. It will read 5.9-6.0. I've purchased some additional R series speakers and none have measured above 6 ohms. 5.7-5.9 is the reading I always get)
the Onkyo is rated at 130 watts per channel. Of course those #'s are never accurate RMS values so I would say with 4 channels driven it would deliver 115-120. × 2 and your right near the highest wattage specs of 250 for the KEF 900 providing it with 230-240.
Recommend purchasing 20 feet of canare 4S11. Got mine on bluejeanscable.com yet there are many other places. Believe 20 feet would be around 30$. It has 2 positive and 2 negative wires and you could connect to your Front L&R and Surround L&R with the same cable. Cut them both at the exact same length.
Tried connecting to both terminals on the towers but noticed no difference in a number of configurations and products.
Don't waste your money. If you feel the need, do what I did and demo one. Go that route to put your mind at ease. Have to admit I had the "more power bug for a few months" thankfully I did demos before learning of no difference.
Be surprised if you noticed any difference other than slightly cleaner bass below 80 Hz. If music is the primary and you want to get what's best for your system, purchase a subwoofer. The 900's can't handle anything below 35-40 Hz. 40 Hz most likely. Buy what's designed to handle the first 3 octaves. You're actually hurting your speakers when you play anything that has a signal below 40 Hz. Outside of classical, pretty sure all genres hit below that frequently. They try, and the 8' woofer puts up a good fight yet they're simply unable to reproduce that frequency.
Best bang for your buck subwoofer I've heard that gets the job done and exceedingly more is the NXG BAS 500 which is $240.
Here's the test bench on my 838 which is rated at 135 to give you a better idea of what your Onkyo will do at 4 channels
Test Bench
Two channels driven continuously into 8-ohm loads:
0.1% distortion at 134.9 watts
1% distortion at 173.4 watts
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 110.5 watts
1% distortion at 129.3 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 84.9 watts
1% distortion at 100.0 watts
Read more at
http://www.soundandvision.com/content/onkyo-tx-nr838-av-receiver-test-bench#PyQ3HaYTkJelDBCJ.99
