1 - 7 of 7 Posts
Hi all :),
I am wondering what one box sollutions are available which can be installed between the Sub RCA out of an AV processor and a power amp? I would like a one box sollution for the rumble filter and any other settings that may prove usefull including maybe EQ?
I am on a budget, this month I am building one of a pair of subs each of which will be around 500L port tuned to 20hz and requiring a HPF around 17hz to 19hz. Each sub will contain two JBL GTO 1502D drivers.
I intend to buy a Behringer EP4000 amp next month for these, but would like to look at what other electronics are required first.
Any suggestions? (which must be available in the UK)
Cheers,
Steve
What is the power input requirement?
This isn't a power device. It receives line-level from your receivers sub-out jack.
do you need a PC for tuning and set up?
You would need to run REW to aid in setting the subsonic filter and any EQ you dialed into it.
Are any of the Behringer units suited?
Not that I know of.
1 - 7 of 7 Posts
