1 - 5 of 5 Posts
Hi,
Im just starting up my HTS and i was wondering which receiver to go good with it, I dont need 7.1, I will be ok with a 5.1 receiver. My budget would be between 500-1000.
I will be using it for movies and music
what receiver would work for me?
recommended receiver for rf-52 speakers ... what receiver would work for me?
All the major brands (Denon, Yamaha, Marantz, Onkyo, Pioneer, etc.) make decent AVRs, and pretty much any receiver will work. You can narrow down the options by determining what features you want/need, and then looking for models that have those features and fall within your budget range.
I agree with eljay, you don't have to worry about anything except the features you want and the amount you want to spend.
Discussion Starter #4
ok thanks, I also have this samsung home theater that I bought couple of years ago, The model is Hw-C560S. I was wondering if that receiver would even work with RF-82 speakers..
just wanted to know if it would work, although i am getting a new speaker this week
thanks for your help! i really appreciate it
1 - 5 of 5 Posts
