Status
Not open for further replies.
1 - 1 of 1 Posts
Projector is fully functional. Condition is very good with minimal scratches to outer shell, etc. Only issue is a thin magenta stripe down the left hand very edge, which can be detected only in the brightest white scenes. This is an optical block issue. I have been masking off 2.5% of the outer image in the settings and you cannot see any of the magenta stripe. Some users have had the similar edge stripe on theirs for a long time and continued to use it, and I probably would have done the same, but I need a brighter projector as we have the lights on all the time, which negates the awesome black levels on this unit. Bulb probably has about 2000 hours on it (counter was recently reset).
SOLD
1 - 1 of 1 Posts
Status
