So as a project, I purchased a used 43UWX10B off of craigslist. I purchased it knowing that it had convergence issues. I ordered the X480293 kit (Sanyo), and replaced the IC's and the resistors. It looks like the repair had already been attempted because of the of the resistors in question had new solder. Anyway, I didn't find any bad resistors but I replaced them all anyway. After hooking everything back up, I turned the TV on and right away, resistor RK54(1.5 Ohm) starts smoking. It's completely discolored and its out of tolerance now. Any suggestions? Also, I took a picture of the "innards" before I took it apart and now I discover that the wire to the blue PCB was not hooked up when I brought it home. Only the green and red were. This leads me to believe that the previous owner knew there was a problem with the blue but it might be a red herring. Any suggestions? Also, where can I buy the correct resistor locally?
