I have modeled with WinISD the speaker and it does not look too good.
Because I want to put it outside, I want a sealed design.
Volume is .719 cubic feet Fc is 33hz for a QTC of .702
When I looked at the response, it is already 3 db down at 100hz, it does not look like those speaker are good candidate for sub.
I have 2 of those and want to put those on my patio, the unit will also be use to sit on it (bench), so the box can be a lot bigger than .719 cubic feet and I will also drive those with an old Sansui amplifier (B2101) that can supply 200WPC.
I have to change the rubber on those as it is all broken, but I saw some kit that are fairly cheap on internet
