1 - 5 of 5 Posts
Hi,
I'm a new member and just bought gear to perform room acoustic measurements, however i seem to be stuck already in the soundcard calibration phase.
HW/SW involved:
Lenovo X201 Windows 7 Enterprise Laptop
Roland UA-55 QUAD-CAPTURE with driver & control panel version 1.0.1 (loop from output 2R to input 2R with 3 meter jack to XLR cable)
REW Version 5.01 Beta
Windows Sound Setting 1:
Windows Sound Setting 2:
Roland Settings 1:
Roland Settings 2:
REW Soundcard Settings 1:
REW Soundcard Settings 2:
REW Soundcard Measurement:
I have made sure to deactivate the "Direct Monitor" button on the soundcard.
Surely the soundcard measurement is not good?? Am I doing something wrong or is my soundcard messed up?
Thanks in advance for any help or pointers!
Hmmmm,
Thanks for the pictures / they do help .
Good, if it was active you would get signal feedback ( which would be another type of trace ) .
It's not good . It's noisy ( those spikes ) and looks to roll-off in the low frequencies a bit before I would expect .
Your overall methodology ( according to your pics ) is correct .
Before blaming the soundcard, make sure ;
> Your computers WiFi is "off" .
> Power your soundcard from the USB buss / not any included supply .
> If you used the mic input / turn off the 48v phantom power .
> Or make your "loop-back" is from "line out to line in" ( ie ; not the mic input on the soundcard ) .
Your welcome ! / I hope something mentioned helps :T
:sn:
Yay! i think that worked!! :T :T
Being a newbie I totally didn't think about the phantom power issue...
Here is the new measurement with soundcard phantom power off:
This is "approved" right??
So excited - thanks for the help Earl! :sn:
That looks better :clap: / though the noise up in the HF area actually increased ( which is weird ) .
That calibration is usable , though I would try a better quality ( loop-back ) cable ( with better shielding ) to see if I could get the visible noise to settle down ( to what you see at around 1000 hz ) .
<> :sn:
Many thanks Earl - I'll see if I can get a hold of a better cable (even though I just bought this one for this purpose... bought it from a Pro Musician store - 3 meter Jack to XLR "Referement Cables (made in Italy) # MCR5 HI.-Q. Microphone Cable 2X0,22 mm²" - at retail 50 $. Murr....)
Once I get going I'm pretty sure I will post my measurement for further guiding! :heehee:
Cheers,
Lars
1 - 5 of 5 Posts
