1 - 3 of 3 Posts
REW 5.17 beta 12 doesn't recognize ASIO driver
Hi there,
Used REW 5.17 beta 7 previously with my M-Audio Revolution 7.1 sound card in ASIO mode and it worked fine.
I'm trying to use 5.17 beta 12 [current at this date] on Windows 10 with the last-available 64-bit drivers for the Revo7.1 which are installed in compatibility mode for Windows Vista.
5.17 beta 12 fails on ASIO driver selection with an error, "Can not load this driver"
Other ASIO applications work fine with the driver/card, as do directsound applications, despite its age and using compatibility mode.
Did something change in the ASIO access with 5.17 beta 12?
Discussion Starter · #2 ·
Interesting:
Reverting to 5.17 beta 7 didn't help, and
I can no longer re-install the drivers [compatibility mode or not].
Any other ASIO applications [both 32 and 64-bit] I've tried still work, though.
The problem may be something Microsoft changed since the Win10 anniversary update since the drivers were installable before that time period and now aren't.
1 - 3 of 3 Posts
