1 - 15 of 15 Posts
Hi,
After upgrading to REW 5.19 beta4 it appears that loading previous measurements, then trying to remove all of them does not work anymore.
After downgrading to REW 5.19 beta3 it works again.
Regards.
That file also works fine for me, whether I use remove all or individually remove the measurements. What happens when you try it? If you look at the REW log files afterwards (their location is shown in the Help -> About REW box) have any errors been logged?
Hi,
When I try to remove all, I have the confirmation dialog (so I confirm) but all the measurements remain.
There is nothing in the log, except init info.
However removing individual measurement works.
Very strange. What happens if you select the other option in the confirm dialog, to not remove? Can you post a screenshot of the dialog?
Thanks Arnaud, glad that's all it was - I noticed the button swap as well, it seems something has changed inside the JRE as I haven't made any change. Edit: Actually on investigation turns out this was a side effect of something I did, I've fixed it for the next beta, sorry.
@giordy60: Clarity, Definition and Centre Time are ISO3382 acoustic parameters that have been added in beta 3 and beta 4.
There are no parameters to set. You can see the values on the Filtered IR graph or on the RT60 graph, if you select the option to 'show data panel'.
1 - 15 of 15 Posts
