1 - 1 of 1 Posts
I have recently reinstalled REW and am delighted to find the JAVA nightmare that had plagued my attempts to use the program in the past is no more.
I can now get accurate, repeatable measurements quickly so I am moving along to measuring each speaker separately. With a tube amp, you don't want to remove the load, and I don't have a balance knob. I suppose I could simply disconnect either the R or L RCA cable going into my preamp and test that way.
Is there a way within the software to limit the signal to L or R? I'm currently using the L for the loop to harvest the timing info. This is obviously not a bid deal, but it would be somewhat easier if I didn't have to fool with the physical connectors.
1 - 1 of 1 Posts
