Hi !
I'm using REW for a while now but there is still a missing feature : it's to use a VST directly to change the sweep and test windows player EQ in REW.
For this, I was hoping Asio version of REW, helped by Console Sound Studio to add VST in the ASIO process, could do this.
But I didn't succeed to make it works...
Is someone try to do this before and succeed ?
Thanks ! :yes:
Do you know how & why you failed ?
Analysis of your process to date , is a crucial first step towards achieving a measure of success when dealing with issues of "virtual patching" .
:sn:
PS : Do you know about VAC ( Virtual Audio Cable ) ?
- You can download a demo version to see if it is of any use to you ( before buying it ) .
- It's also worth downloading to see if it plays nice with your existing soundcards drivers ( it wasn't that compatible my M-Audio cards drivers / BSOD > blue screens of death & all that ).
I failed because the in and out is not clear in the Asio choice in Console...
But I will try your Virtual audio cable, thanks !
(I think I already use it a long time ago)
By the way, there is a problem in REW : there is a choice of output in Asio and it is left or right chanel but can't out to the both together !
I prefer to measure right and left separately (we can't do it before with Java), but to check global response it's useful to measure both.
What exactly are trying to achieve with REW ?
For instance ;
(i) Are you aware that REW can currently create & then export ( as a wave file , mono or stereo ) its' User-Generated Correction ( EQ ) Filter ?
> That wave file ( EQ filter ) can then be VST hosted within the dsp section ( within a convolver that hosts wave files ) of the playback software ( like Windows Media Player , FooBar, Media Center ) .
> This will provide custom EQed playback ( for your speakers ) as long as your music is played by the software hosting the EQ correction file .
> This approach is purely software based ( the next approach , is bit of both ) .
(ii) The latest & next generation of soundcards are putting more DSP processing power right onto the soundcard, allowing things like VST plugins to be hosted within the soundcards own virtual mixer ( ie; driver ) .
> As I see it, this is the direction all mid to high lprice cards are going .
> Waiting ( & then buying ) a new sound card ( with VST hosting capabilites ) is quite likely the best way to go here ( at least for me ).
> This approach relieves the computers CPU of all the high overhead ( number crunching ) necessary for multiple channels of convolved EQ .
> Once your speakers' correction EQ is hosted within your soundcard then ( of course ) any audio routed through the cards outputs gets EQed .
:sn:
Select the other output you want to use as the reference output, the same signal will then appear on both.
Oh ok thanks, I was afraid to try this ! :R
But well done Earlk, Virtual Audio Cable was the part missing in my setup to pass the sound through Console and set up the VST I use in Foobar. :clap:
For instance ;
I saw it but never try. Now, I can setup my EQ and see directly his effect in REW ! :T
:sn:
I just have an Spdif transport, no sound card.
