1 - 2 of 2 Posts
As I often play with JAVA/ASIO input/ouput, i would like to know if it's possible to select the config JAVA or ASIO with command line ( something like Roomeqwizard.exe -ASIO or the same way with the .jar )
I found a solution to write the registry with a pre-config JAVA (or ASIO) and it works but i think it's not a clean way
1 - 2 of 2 Posts
