1 - 4 of 4 Posts
G
Guest
When I start REW with my Tascam US-122 plugged in, I get the following error:
No input mixers available
supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
If I click OK the program opens, but when I go to settings and look at input devices for 44.1kHz, I see four items in the pull-down list:
Default Device
MacOSX, Core...
blank
blank
("blank" means a blank line). Presumably the Tascam should be in one or both of the blank lines. Selecting the upper blank gives a javascript error or sometimes a crash; the lower one causes a crash.
This is a Macbook Pro running OSX 10.4.11. I've got the latest drivers for the Tascam.
Under 10.4 you need to set the sampling rate as 44.1kHz and select the default input and output. Only the on-board audio input is available to java apps like REW, you need 10.5 to get Apple's fix for that.
G
Guest
Discussion Starter #4
OK - I'll work around it. Thanks.
1 - 4 of 4 Posts
