1 - 7 of 7 Posts
Running REW 5.17 beta 7 for multiple instances on a Windows 7 desktop machine and after a couple of operations of any kind the display just goes whacko, jumping all over the place, completely unusable. I have a feeling I am not the original discoverer of this problem, but I missed any posts about it. Help, John?
Typically a video driver issue, but the interactions between Java and the video driver are sometimes not easily resolved. If it happens again you can try disabling hardware graphics acceleration for Java in REW using the startup option described here.
Discussion Starter #5
Thanks, John. One of the "extra" video programs that came with a recent video driver update was to blame, I uninstalled it (& updated Java just for fun and because I needed to anyway) and rebooted a couple of times, and the issue was gone. It had me panicking a little. But REW 5.17 beta 7 with multiple instances allowed has run just fine since then.
Discussion Starter #7
Of course. The two programs in question were Raptr.com and Plays.tv
I was trying out A-V capture programs at the time, and on one software install ended up with a Yahoo! search browser showing up at boot. Nothing against Yahoo!, I just did not want that critter on my computer. Somewhere around that time, updated video drivers (AMD) also showed up. Raptr.com and Plays.tx came either with the AMD video drivers or with the Yahoo search thing, and thinking through the details, I am not certain which it was, so I mention them both. The Yahoo! search window was finally eliminated via registry editing and a spyware search and destroy program.
In the process of installing and uninstalling REW, I noticed that the two programs in question always showed up as "most recently installed" on the Windows 7 Control Program uninstall a program screen. That should not be the case, it is almost "virusy" behavior.
Once I uninstalled both and rebooted a couple of times until a nice clean startup was completed, the REW display problem vanished. REW was the only application with the unstable display behavior.
1 - 7 of 7 Posts
