Hi Folks
This is my first post so as usual be gentle
I have read extensively about room acoustics and room tratments and really appreciated the effect the room could be having on my home theater but the more I read the more confused and frustrated I get.
I have read loads on Subwoofer placement but am non the wiser where to position mine before doing any EQ.
Ive looked at buying the "XTZ Room Analyzer Package " but wonder if this is a false economy if I end up buying a SVS AS-EQ1 SubEQ
Of course there ia also the free REW software, brilliant graphs but how does an idiot like me analyse and understand them
If it shows a hump / dip does it also show where in the room that is? how do you treat it? reposition your sub? adjust something on your AVR ?
Because REW is not the same as a SVS AS-EQ1 SubEQ which I believe is left in line how do you adjust the freq reponse.
By now you should realise I am stupid and need to either give up or get some back to basics help which I havn't so far found searching around on REW
My dedicated room is an awkward 20ft X 17ft + a 8ft 7"X 31.5" Alcove , the room is 8' High
My System is a Panasonic AE-3000 , Denon 2500 BT Transport, Yahama Z7 AVR, M&K S-150 L/C/R, M&K SS-150 Surrounds , Polk Ls/FX Rear Back and a M&K MX-350 Sub.
Can anyone point me in the right direction?
Thanks in advance
Thanks in advance
