1 - 9 of 9 Posts
Good day
I've been studying and watching a lot of Videos and resources online regarding the setup/calibration of REW.
I am running Mac OS 10.8.3 with REW v5.12
Under Preferences one can set the Input/Output device. I am unable to select/see which input/output to use for the calibration test, which makes it nearly impossible to know which input/output to use.
Any advice perhaps?
If it isn't working with the MOTU selected as both the output device and output and input device and input could try leaving all the fields set as default. Is the output working OK?
Seems like I have found the solution. I have a unit that supports multiple inputs/outputs. I changed the default in and outs to 1 and 2 and looped output 1 to input 1. I am now receiving signal.
1 - 9 of 9 Posts
