1 - 3 of 3 Posts
REW Author
Do you hear the test sweep OK when you measure?
Is the UMIK-1 set as the default audio input in the Mac's Audio setup?
Is REW set to use the default output and input?
The sweeps sound fine.
The umik is set as default, although REW still tries to use the MacBook built in mic. Only way to get it to use the umik is by running Linein software and setting the mic as the default there and choose sound flower 2ch as the input. Haven't been able to get consistent results on the Mac. Going to try it on my windows laptop.
1 - 3 of 3 Posts
