Hello. I bought an interface to allow me to hook up my computer to my TV but have an unexpected problem. I can not view the lower half of the REW screen (everything else views fine???) no matter what I try, which is where the settings are that I need to get started. Has anyone had a similar problem that can offer some advice or is there another way to set the device types?
Thanks! Greg
What screen resolution are you using? Need 1024x768 minimum, some TVs only handle VGA (640x480).
Discussion Starter #4
Discussion Starter #5
That worked, but it's very hard to read. Thanks!
If you are running XP you can go into Control Panel>Display>Settings>Advanced>DPI settings and adjust the size of everything on the screen that way. (May mean a restart)
When I first obtained my LCD screen everything was sharp but just too small to read.
This tip from another forum member worked nicely. :T
