Ok! Got a little confused. Don't have laptop at the moment and am looking to get one.
I thought read something about having line out and a line in jacks. as long as I have a usb for mic and a headphone/mic jack I should be good. Dang these laptops are not really getting any cheaper. If I have to get one I should get a decent one. IDK
REW Author
If you are using a USB mic for input then you can use the headphone connector for output, whether it is a combo connector or headphone only.
Discussion Starter #5
Is there a difference in where one purchases a usb mic from?
REW Author
Only if you buy it from someone who does their own calibration (such as Cross Spectrum). If you are using the manufacturer's calibration then it makes no difference where you get the mic.
